Here you go meg. There are a number of tyre tests that have been done specifically with motorhomes and Continental consistently come out on top. They always have dramatically shorter braking distances than all the other products and they are often praised on their stability.
I recently did an article on the importance of checking your
motorhome tyres before the holidays which can be seen
here: But what should you do if they need changing? Which tyre should you buy for your motorhome? Let’s investigate!
If your vehicle was bought new then there is a good chance that it was supplied with a specific camping tyre. Continental, Michelin & Pirelli all make these camper specific products although Michelin & Continental are certainly the most common. If you take a look at your current tyres and you may see wrote on the sidewall;
Continental Vanco Camper,
Michelin Agilis Camping or XC Camping – these are all ‘proper’ motorhome tyres.
So what are
camping tyres?
These tyres are designed specifically for use on motorhomes, the main difference is that they have tougher sidewalls. This toughness helps in 2 ways, firstly they are more suitable to run at higher pressures that are required for motorhomes, and secondly the rigidity reduces tyre movement and stops the vehicle from swaying around, particularly whilst cornering. There are also subtle differences in the tread compound which gives the tyres improved grip on wet surfaces and some differences in construction that make the tyre more resistant to abrasions & impacts.
Can I use normal
van tyres?
Absolutely, it is still legal and safe to use regular
van tyres as long as the load rating is high enough to carry the weight of the vehicle. By using a standard van tyre you will of course not benefit from the features detailed above. The main reason people fit standard van tyres is because of the cost implications of fitting
motorhome tyres. The camper equivalent tends to be about 15% more which can equate to upwards of £60 a set. Personally I think the cost is justified and worth the additional cost.
Which brand?
As mentioned Continental & Michelin are the most common
motorhome tyres fitted by manufacturers. Michelin tend to be the more expensive of the two and many purchasers have an idea that they are the best manufacturer. Well when it comes to camper tyres this doesn’t appear to be the case! There are a number of tyre tests that have been done specifically with motorhomes and Continental consistently come out on top. They always have dramatically shorter braking distances than all the other products and they are often praised on their stability.
A note on availability
When it comes to changing your tyres I would also advise starting to investigate the process long before any trips away. During peak times of the year (April, May) some camper tyres can become scarce so please allow plenty of time. If you can’t see what you need online give a
reputable dealer a call to check expected dates for you.
Happy camping
Have a look at Tyremen’s great
winter tyres packages. Or ring 0845 807 808 for more info.
Max pressure note – Feb 14
Off the back of a few comments about max pressures on the Vanco Camper tyre I thought it would be useful to clarify that the 215/70R15 tyre can be inflated to 80psi when using on motorhomes. There is a confusing message on the side wall that states max pressure 69psi but this is just intended for regular commercial use. The following graphic can also be found on the side of the tyre which demonstrates that then when using on a motorhome this max pressure can be rai
sed to 5.5 bar, which is equal to 80psi – I hope this helps.
